跳转到主内容
加入维修社区 - 创建账户
Fujifilm Instax Mini Eight Camera Shell Replacement
你所需要的
  1. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: 步骤 1 中的图像 1,3 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: 步骤 1 中的图像 2,3 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: 步骤 1 中的图像 3,3
    • Start off by looking at your camera and rotating it to locate all the screws. There should be nine screws in all.
    • One screw is hidden below the oval plastic cover of printers opening. Remove the cover to unveil the ninth screw.
  2. Fujifilm Instax Mini Eight Camera Shell Replacement: 步骤 2 中的图像 1,3 Fujifilm Instax Mini Eight Camera Shell Replacement: 步骤 2 中的图像 2,3 Fujifilm Instax Mini Eight Camera Shell Replacement: 步骤 2 中的图像 3,3
    • Press the tab down in order to unlatch the film compartment cover.
    • Remove the film from the compartment (if any is present)
    • Remove the compartment cover completely.
    • Begin by using the small #00 Philips head screwdriver and turning at a counter-clockwise fashion to remove screws.
  3. Fujifilm Instax Mini Eight Camera Shell Replacement: 步骤 3 中的图像 1,3 Fujifilm Instax Mini Eight Camera Shell Replacement: 步骤 3 中的图像 2,3 Fujifilm Instax Mini Eight Camera Shell Replacement: 步骤 3 中的图像 3,3
    • Use the plastic opening tools and spudger to safely remove the front shell casing.
  4. Fujifilm Instax Mini Eight Camera Shell Replacement: 步骤 4 中的图像 1,2 Fujifilm Instax Mini Eight Camera Shell Replacement: 步骤 4 中的图像 2,2
    • Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
    • Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
    • At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
结论
13等其他人完成本指南。
Bo W
于10/02/12注册
1,025 声望
创作了5篇指南
团队
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 的会员
USFT-MEIER-F15S4G1
4 名成员
创作了26篇指南
18指南评论
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
princesslsy - 回复
but where near the exit? i cannot find it
Emily Birkler -
It's at the top of the camera where you get picture.
xxx -
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - 回复
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
Siti Syuhanna hussein - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 68
过去 30 天: 340
总计 69,714
