跳转到主内容
Fujifilm Instax Mini 8 Infrared Blaster Replacement
你所需要的
  1. Fujifilm Instax Mini 8 Infrared Blaster Replacement, Infrared Blaster: 步骤 1 中的图像 1,3 Fujifilm Instax Mini 8 Infrared Blaster Replacement, Infrared Blaster: 步骤 1 中的图像 2,3 Fujifilm Instax Mini 8 Infrared Blaster Replacement, Infrared Blaster: 步骤 1 中的图像 3,3
    • First, push in the lens and remove the two AA batteries.
  2. Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 2 中的图像 1,2 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 2 中的图像 2,2
    • Open the rear compartment and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 3 中的图像 1,3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 3 中的图像 2,3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 3 中的图像 3,3
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 4 中的图像 1,3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 4 中的图像 2,3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 4 中的图像 3,3
    • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
  5. Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 5 中的图像 1,3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 5 中的图像 2,3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 步骤 5 中的图像 3,3
    • Locate the IR blaster, remove the connecting wire ribbon by prying the connector latch open on the motherboard, then sliding it out. Once the wire ribbon is disconnected, the IR blaster can be lifted away from the motherboard.
结论
另外一个人完成了本指南。
Boyang Wu
于10/02/12注册
955 声望
创作了5篇指南
团队
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 的会员
USFT-MEIER-F15S4G1
4 名成员
创作了24篇指南
2条评论
Where can I find the replacements (ir blaster)? What is the function of this part. I dropped my camera and the flash won’t turn on and films develop completely black even in broad daylight.
Jenna - 回复
Can that part be pushed back when cleaning it with a qtip? I think I pushed a bit hard but I don’t know. If it’s pushed back a bit will it effect its use?? Please help!
Orange - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 60
总计 11,206
