简介
The main purpose of this page is to assure the owner of a Fujifilm Instax Mini 8 is capable of disassembling the camera in order to remove and replace the flash unit, if there was to ever be any problems with the flash. Before attempting repairs, please take note of certain risks of receiving shock from the camera's flash capacitor. Also make sure to ground yourself before operating on the camera's motherboard or you might discharge static to crucial components.
你所需要的
Remove the two Phillips #00 screws from the bottom of the camera.
Remove the two screws on the side of the camera.
Additionally, there are two screws in the battery compartment which also need to be removed.
There is also a screw underneath the cover for the picture eject slot
I had the same problem with my camera which I have had for about 10 years now all the red lights on my camera came on and I could not use my camera to FIX this problem you need to turn the camera on and replace the batteries with new batteries and this will reset your camera I did this last night and my camera is as good as new now
With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
4等其他人完成本指南。
10条评论
Where can I purchase the flash unit?
Hi, did you ever find out where to replace the flash light unit?
Hello. Can the motherboard of the camera be replaced?
Amal Amjad - 回复
Where can I buy a flash unit for a Fuji instax mini 70?
i also need to find out where to buy a flash unit for my fuji instax mini 70 .been try to do web searches but it seems to be so dam hard to find where to buy one
I have a Instax 7s… I want to install a switch in the camera in order to mod it to have a “NO FLASH” option… Where should I put the switch? I was thinking in dividing one of the capacitor areas or the red wire of the flash unit. Any advice?
I also want to do this for the ejecting motor in order to do double expositions (Yep. I’ll be really modding this camera hahaha)
Any advices?
