跳转到主内容
Fujifilm Instax Mini 8 Capacitor Replacement
你所需要的
  1. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: 步骤 1 中的图像 1,3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: 步骤 1 中的图像 2,3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: 步骤 1 中的图像 3,3
    • First, push in the lens and remove the two AA batteries.
  2. Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 2 中的图像 1,2 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 2 中的图像 2,2
    • Open the rear compartment and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 3 中的图像 1,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 3 中的图像 2,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 3 中的图像 3,3
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 4 中的图像 1,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 4 中的图像 2,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 4 中的图像 3,3
    • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
  5. Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 5 中的图像 1,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 5 中的图像 2,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 5 中的图像 3,3
    • Locate the photo-flash capacitor, then find all the connecting wires to the motherboard and battery compartment. Take notes to which exact wires they are to limit mistakes.
  6. Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 6 中的图像 1,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 6 中的图像 2,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 6 中的图像 3,3
    • Carefully pry out the capacitor with a spudger or plastic opening tools.
  7. Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 7 中的图像 1,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 7 中的图像 2,3 Fujifilm Instax Mini 8 Capacitor Replacement: 步骤 7 中的图像 3,3
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
结论
5等其他人完成本指南。
Bo W
于10/02/12注册
1,010 声望
创作了5篇指南
团队
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 的会员
USFT-MEIER-F15S4G1
4 名成员
创作了26篇指南
3指南评论
Hi There! I need a new capacitor for my daughter's Fuji Instax Mini 9. Do you supply? I am in South Africa.
Kuschi - 回复
Hi, any recommendations on where can find a shop in Kl Malaysia to fix my instax mini 8? Thanks in advance !
Miss.G - 回复
Bonjour, j'ai un instax mini 11 qui clignote orange rapidement.
Après divers manipulation de réinitialisation et de changement de pile pour des neuves rien y fait.
Est-ce que ça pourrait être un problème de condensateur qui empêche le flash de charger correctement ? Et mettrais donc l'appareil en erreur ?
Elise Tibbo - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 156
总计 27,628
