跳转到主内容
Fujifilm Finepix S1800 Top Cover Replacement
你所需要的
  1. Fujifilm Finepix S1800 Top Cover Replacement, Back Cover Assembly: 步骤 1 中的图像 1,1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Top Cover Replacement: 步骤 2 中的图像 1,1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Top Cover Replacement: 步骤 3 中的图像 1,1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Top Cover Replacement: 步骤 4 中的图像 1,2 Fujifilm Finepix S1800 Top Cover Replacement: 步骤 4 中的图像 2,2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: 步骤 5 中的图像 1,2 Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: 步骤 5 中的图像 2,2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Finepix S1800 Top Cover Replacement: 步骤 6 中的图像 1,1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Finepix S1800 Top Cover Replacement: 步骤 7 中的图像 1,1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
  8. Fujifilm Finepix S1800 Top Cover Replacement, Top Cover: 步骤 8 中的图像 1,1
    • Lift the flash.
    • Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
  9. Fujifilm Finepix S1800 Top Cover Replacement: 步骤 9 中的图像 1,2 Fujifilm Finepix S1800 Top Cover Replacement: 步骤 9 中的图像 2,2
    • Remove the 4 mm screws from the left and right sides of the camera with the JIS #1 screwdriver.
  10. Fujifilm Finepix S1800 Top Cover Replacement: 步骤 10 中的图像 1,2 Fujifilm Finepix S1800 Top Cover Replacement: 步骤 10 中的图像 2,2
    • Switch the lever to disconnect the micro strip that connects the top plate.
    • Do not rip the micro strip.
  11. Fujifilm Finepix S1800 Top Cover Replacement: 步骤 11 中的图像 1,1
    • Remove the top cover.
结论
另外一个人完成了本指南。
Ryan Rockford
于02/15/17注册
618 声望
创作了5篇指南
团队
USF Tampa, Team 8-6, Eyestone Spring 2017 USF Tampa, Team 8-6, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G6
4 名成员
创作了10篇指南
一条评论
I had a problem with my Fuji Fine pix S 2950 (similar case) On / Off switch, this guide was invaluable to help me get into the top case moulding.
The fault was a crack around a solder pad were the SMT switch is mounted on the PCB , a simple solder job but an absolute bugger to get to.
Thank you for this simple and straight forward guide.
Bob Wilkins - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 625
