简介
Is the flash not flipping up on your Fujifilm Finepix S1800 camera? It might be time to replace the top cover plate. This guide will show you how to replace the top cover.
你所需要的
Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
Gently lift the back cover away from the device.
Lift the flash.
Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
另外一个人完成了本指南。
一条评论
I had a problem with my Fuji Fine pix S 2950 (similar case) On / Off switch, this guide was invaluable to help me get into the top case moulding.
The fault was a crack around a solder pad were the SMT switch is mounted on the PCB , a simple solder job but an absolute bugger to get to.
Thank you for this simple and straight forward guide.
