简介
Is the button to take a photo on your Fujifilm Finepix S1800 jammed or broken? This guide will show you step by step on how to replace the jammed or broken button.
你所需要的
Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
Gently lift the back cover away from the device.
Lift the flash.
Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
Remove the two 2 mm screws underneath the plate with the Phillips #000 screwdriver.
2等其他人完成本指南。
