跳转到主内容
Fujifilm Finepix S1800 Shutter Button Replacement
你所需要的
  1. Fujifilm Finepix S1800 Shutter Button Replacement, Back Cover Assembly: 步骤 1 中的图像 1,1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 2 中的图像 1,1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 3 中的图像 1,1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 4 中的图像 1,2 Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 4 中的图像 2,2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Finepix S1800 Shutter Button Replacement, LCD Screen: 步骤 5 中的图像 1,2 Fujifilm Finepix S1800 Shutter Button Replacement, LCD Screen: 步骤 5 中的图像 2,2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 6 中的图像 1,1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 7 中的图像 1,1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
  8. Fujifilm Finepix S1800 Shutter Button Replacement, Top Cover: 步骤 8 中的图像 1,1
    • Lift the flash.
    • Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
  9. Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 9 中的图像 1,2 Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 9 中的图像 2,2
    • Remove the 4 mm screws from the left and right sides of the camera with the JIS #1 screwdriver.
  10. Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 10 中的图像 1,2 Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 10 中的图像 2,2
    • Switch the lever to disconnect the micro strip that connects the top plate.
    • Do not rip the micro strip.
  11. Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 11 中的图像 1,1
    • Remove the top cover.
  12. Fujifilm Finepix S1800 Shutter Button Replacement, Shutter Button: 步骤 12 中的图像 1,1
    • Remove the two 2 mm screws underneath the plate with the Phillips #000 screwdriver.
  13. Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 13 中的图像 1,2 Fujifilm Finepix S1800 Shutter Button Replacement: 步骤 13 中的图像 2,2
    • The button should fall right out.
结论
2等其他人完成本指南。
Ryan Rockford
于02/15/17注册
618 声望
创作了5篇指南
团队
USF Tampa, Team 8-6, Eyestone Spring 2017 USF Tampa, Team 8-6, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G6
4 名成员
创作了10篇指南
一条评论
CAUTION! Different hardware versions! Following this guide might destroy your camera!
My S1800 had LCD not screwed to the body, but glued to the back cover. At the step 4 it came off together with the cover, destroying the ribbon cable, which is really short and fragile.
AntonG - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 1,290
