跳转到主内容
Fujifilm Finepix S1800 Back Cover Assembly Replacement
你所需要的
  1. Fujifilm Finepix S1800 Back Cover Assembly Replacement, Back Cover Assembly: 步骤 1 中的图像 1,1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Back Cover Assembly Replacement: 步骤 2 中的图像 1,1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Back Cover Assembly Replacement: 步骤 3 中的图像 1,1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Back Cover Assembly Replacement: 步骤 4 中的图像 1,2 Fujifilm Finepix S1800 Back Cover Assembly Replacement: 步骤 4 中的图像 2,2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
结论
另外一个人完成了本指南。
Ryan Rockford
于02/15/17注册
618 声望
创作了5篇指南
团队
USF Tampa, Team 8-6, Eyestone Spring 2017 USF Tampa, Team 8-6, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 403
