跳转到主内容
Fujifilm Finepix S1000fd Leather Grip Replacement
你所需要的
  1. Fujifilm Finepix S1000fd Leather Grip Replacement, Rear Cover Casing: 步骤 1 中的图像 1,2 Fujifilm Finepix S1000fd Leather Grip Replacement, Rear Cover Casing: 步骤 1 中的图像 2,2
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Leather Grip Replacement: 步骤 2 中的图像 1,2 Fujifilm Finepix S1000fd Leather Grip Replacement: 步骤 2 中的图像 2,2
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Leather Grip Replacement: 步骤 3 中的图像 1,1
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
  4. Fujifilm Finepix S1000fd Leather Grip Replacement, Leather Grip: 步骤 4 中的图像 1,1
    • Using the metal spudger, place it in between the leather grip and the black plastic compartment
  5. Fujifilm Finepix S1000fd Leather Grip Replacement: 步骤 5 中的图像 1,1
    • Repeat Step 4 for the other side
    • Remove the leather grip
结论
Lizzie Eller
于01/25/17注册
422 声望
创作了4篇指南
团队
Cal Poly, Team 8-7, Banghart Winter 2017 Cal Poly, Team 8-7, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G7
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 457
