简介
If your flash will no longer pop up and you have followed the troubleshooting steps you can try replacing the spring by following this guide. This can be a complicated process though, so make sure you have tried other options first.
你所需要的
Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
Open the flash by pushing the button or prying it up with the plastic opener tool
Locate the spring and grasp with the tweezers. Pinch and compress the spring to remove it from the camera housing. Slide the lever that was holding the spring out of the camera housing.
3条评论
(1) Between step 5 & step 7 you should have remove the 2 screws under the flash pop up.
(2) Wish you had a closer view of the spring installation.
The flash appears to be a chronic problem with my Fuji camera. I have had it for repair with agent 3 times already! Repairs have cost more than the camera.It has happened again on a brand new flash, so I’m trying to have a look myself to assess if I can repair this issue which seems to be more of a defect in the camera.
Thanks for a great guide…….so, I can see the top of the spring in your demo; but what I would like to see is the other end of the spring…. as from what I can see (on my camera) my spring does not appear to be broken. In fact the technician always says that he reinforced it(?) and I would like your opinion before proceeding .
Thanks a lot
