跳转到主内容
Fujifilm Finepix S1000fd Display Screen Replacement
你所需要的
  1. Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: 步骤 1 中的图像 1,2 Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: 步骤 1 中的图像 2,2
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Display Screen Replacement: 步骤 2 中的图像 1,2 Fujifilm Finepix S1000fd Display Screen Replacement: 步骤 2 中的图像 2,2
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Display Screen Replacement: 步骤 3 中的图像 1,1
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
  4. Fujifilm Finepix S1000fd Display Screen Replacement, Display Screen: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to lift up the right side of the display screen.
  5. Fujifilm Finepix S1000fd Display Screen Replacement: 步骤 5 中的图像 1,1
    • Once the screen is out, you will realize that it is still connected to the ribbon cable. To unplug this ribbon cable, use a plastic opening tool to pull up and to the left on the ribbon cable connector and release the ribbon cable.
  6. Fujifilm Finepix S1000fd Display Screen Replacement: 步骤 6 中的图像 1,1
    • Using your PH00 screwdriver, unscrew the 0.5mm screw located on the bottom left hand corner where the display screen used to be.
  7. Fujifilm Finepix S1000fd Display Screen Replacement: 步骤 7 中的图像 1,1
    • Use the PH00 screwdriver to unscrew the 0.5mm screws located near the top left corner, top right corner, and bottom right corner.
  8. Fujifilm Finepix S1000fd Display Screen Replacement: 步骤 8 中的图像 1,1
    • Lift up the gray component where the display screen use to sit in.
结论
另外一个人完成了本指南。
Lizzie Eller
于01/25/17注册
422 声望
创作了4篇指南
团队
Cal Poly, Team 8-7, Banghart Winter 2017 Cal Poly, Team 8-7, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G7
4 名成员
创作了10篇指南
一条评论
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
mike.osupe - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 905
