跳转到主内容
Fujifilm Finepix S1000fd Battery Replacement
  1. Fujifilm Finepix S1000fd Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the camera upside down.
  2. Fujifilm Finepix S1000fd Battery Replacement: 步骤 2 中的图像 1,1
    • Flick the switch on the right side of the camera, and bring it downwards, while simultaneously lifting up the cover.
    • While the switch is held down, lift up the battery compartment cover.
  3. Fujifilm Finepix S1000fd Battery Replacement: 步骤 3 中的图像 1,1
    • Observe that the signs on the battery compartment will show you how to insert the 4 AA batteries.
    • There should be positive battery signs near the bottom slot and the third slot from the bottom.
    • There should be negative battery signs near the top slot and the second slot from the bottom.
结论
另外一个人完成了本指南。
Somya Lalwani
于01/25/17注册
113 声望
撰写一个指南
团队
Cal Poly, Team 8-7, Banghart Winter 2017 Cal Poly, Team 8-7, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G7
4 名成员
创作了10篇指南
3条评论
My S1000 takes 1 battery not five…
francanadaswan - 回复
My Fuji S1000 digital camera takes 1 battery, not five. Where can I get a replacement? Nothing on Amazon.
francanadaswan - 回复
My s1000fd takes 4 batteries... how would i clean it after the batteries leaked in the battery well? is it salvageable?
Beckmansbabe - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 37
总计 1,695
