跳转到主内容
Fujifilm Finepix F10 6.3 MP Shutter Button Replacement
你所需要的
  1. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 2 中的图像 1,1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 3 中的图像 1,1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 4 中的图像 1,3 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 4 中的图像 2,3 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 4 中的图像 3,3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, LCD: 步骤 5 中的图像 1,1
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 6 中的图像 1,1
    • Slide casing out using the spudger.
  7. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 7 中的图像 1,2 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 7 中的图像 2,2
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
  8. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, Shutter Button: 步骤 8 中的图像 1,2 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement, Shutter Button: 步骤 8 中的图像 2,2
    • Pull on the shutter button display data cable on the end connected to the motherboard until it slides out.
  9. Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 9 中的图像 1,2 Fujifilm Finepix F10 6.3 MP Shutter Button Replacement: 步骤 9 中的图像 2,2
    • While slightly rotating the shutter button and data cable counter-clockwise, pull out until whole component comes out.
    • When inserting the new shutter button and data cable component, be sure it is placed properly into the camera or it will not function correctly.
结论
另外一个人完成了本指南。
Sarah Looper
于03/11/13注册
100 声望
创作了7篇指南
团队
Clemson, Team 13-4, Benson Spring 2013 Clemson, Team 13-4, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G4
2 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 1,044
