跳转到主内容
Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement
你所需要的
  1. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 步骤 2 中的图像 1,1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 步骤 3 中的图像 1,1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 步骤 4 中的图像 1,3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 步骤 4 中的图像 2,3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 步骤 4 中的图像 3,3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: 步骤 5 中的图像 1,2 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: 步骤 5 中的图像 2,2
    • Remove electrowind strip from font cover.
    • The front cover does not have to be separated from the device for this step or the next ones.
  6. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 步骤 6 中的图像 1,1
    • Remove lens data cable by gently pulling it out.
  7. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: 步骤 7 中的图像 1,1
    • Remove lens filter.
    • There are multiple square pieces, so be sure to remove them all.
结论
另外一个人完成了本指南。
Sarah Looper
于03/11/13注册
100 声望
创作了7篇指南
团队
Clemson, Team 13-4, Benson Spring 2013 Clemson, Team 13-4, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G4
2 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 828
