跳转到主内容
Fujifilm FinePix Z5 LCD Screen Replacement
你所需要的
  1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 2 中的图像 1,2 Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 3 中的图像 1,3 Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 3 中的图像 2,3 Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 4 中的图像 1,2 Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Pull the LCD screen to the left slightly, lift it and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 5 中的图像 1,2 Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Using a small flat head screw driver, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Using your index finger, guide the cable of the new screen into place. Lock it in by pushing the black lever back down.
结论
Kyle Kaczmar
于02/10/12注册
14 声望
撰写一个指南
团队
James Madison, Team 3-4, Klein Spring 2012 James Madison, Team 3-4, Klein Spring 2012 的会员
JMU-KLEIN-S12S3G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 946
