跳转到主内容
Fujifilm FinePix Z1 Battery Replacement
  1. Fujifilm FinePix Z1 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the battery on the display screen of the camera is charged. If it is not fully charged, plug into charger and turn the camera on.
    • If the battery image on the display screen does not show then you will need to check the battery.
  2. Fujifilm FinePix Z1 Battery Replacement: 步骤 2 中的图像 1,1
    • Turn the camera to the bottom and find the battery access door on the left side.
  3. Fujifilm FinePix Z1 Battery Replacement: 步骤 3 中的图像 1,2 Fujifilm FinePix Z1 Battery Replacement: 步骤 3 中的图像 2,2
    • Open the battery access door by pushing down and up on the spring-hinged door.
    • Check that there is no obvious damage or reason for a faulty battery.
  4. Fujifilm FinePix Z1 Battery Replacement: 步骤 4 中的图像 1,1
    • Push the yellow tab to eject the battery.
  5. Fujifilm FinePix Z1 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery and replace with a new one.
结论
Carra
于01/30/18注册
533 声望
创作了4篇指南
团队
Baylor, Team S2-G4, Johnson Spring 2018 Baylor, Team S2-G4, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 17
总计 681
