跳转到主内容
Fujifilm FinePix Z1 Battery Access Door Spring Replacement
你所需要的
  1. Fujifilm FinePix Z1 Battery Access Door Spring Replacement, Battery Access Door Spring: 步骤 1 中的图像 1,1
    • Locate the Battery Access Door on the bottom of the camera.
    • Ensure that the door has no obvious cracks or damage.
    • See if the door slides out and opens completely.
  2. Fujifilm FinePix Z1 Battery Access Door Spring Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix Z1 Battery Access Door Spring Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix Z1 Battery Access Door Spring Replacement: 步骤 2 中的图像 3,3
    • Apply pressure to the door and pop the component out.
    • Using a H0.7 bit, push the rod out of the door to remove it from the camera.
    • Adjust or replace the spring.
结论
Carra
于01/30/18注册
533 声望
创作了4篇指南
团队
Baylor, Team S2-G4, Johnson Spring 2018 Baylor, Team S2-G4, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 8
总计 146
