简介
The battery access door for the Fujifilm FinePix Z1 is attached with a spring and a rod that allows for easy opening and closing of the door. If the screw is damaged or has somehow been jammed, the door may not open or close correctly. This guide will aid you in fixing the malfunctioning pieces.
你所需要的
Locate the Battery Access Door on the bottom of the camera.
Ensure that the door has no obvious cracks or damage.
See if the door slides out and opens completely.
即将完成!
结论
