跳转到主内容
Fujifilm FinePix XP80 Lens Replacement
你所需要的
  1. Fujifilm FinePix XP80 Lens Replacement, Battery: 步骤 1 中的图像 1,3 Fujifilm FinePix XP80 Lens Replacement, Battery: 步骤 1 中的图像 2,3 Fujifilm FinePix XP80 Lens Replacement, Battery: 步骤 1 中的图像 3,3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Lens Replacement: 步骤 2 中的图像 1,1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Lens Replacement, Exterior Case: 步骤 3 中的图像 1,1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Lens Replacement: 步骤 4 中的图像 1,1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Lens Replacement: 步骤 5 中的图像 1,1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Lens Replacement: 步骤 6 中的图像 1,1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Lens Replacement: 步骤 7 中的图像 1,1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Lens Replacement: 步骤 8 中的图像 1,1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Lens Replacement: 步骤 9 中的图像 1,2 Fujifilm FinePix XP80 Lens Replacement: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Lens Replacement, Interior Case: 步骤 10 中的图像 1,1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Lens Replacement: 步骤 11 中的图像 1,1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Lens Replacement: 步骤 12 中的图像 1,1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Lens Replacement: 步骤 13 中的图像 1,3 Fujifilm FinePix XP80 Lens Replacement: 步骤 13 中的图像 2,3 Fujifilm FinePix XP80 Lens Replacement: 步骤 13 中的图像 3,3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Lens Replacement: 步骤 14 中的图像 1,1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Lens Replacement, Lens: 步骤 15 中的图像 1,1
    • Using a plastic opening tool, remove the entire lens housing.
    • Install the new lens and housing (it is replaced as a single unit).
结论
Amanda Lewis
于09/25/16注册
317 声望
创作了3篇指南
团队
USF Tampa, Team 1-3, Cagle Fall 2016 USF Tampa, Team 1-3, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G3
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,502
