跳转到主内容
Fujifilm FinePix XP80 Interior Case Replacement
你所需要的
  1. Fujifilm FinePix XP80 Interior Case Replacement, Battery: 步骤 1 中的图像 1,3 Fujifilm FinePix XP80 Interior Case Replacement, Battery: 步骤 1 中的图像 2,3 Fujifilm FinePix XP80 Interior Case Replacement, Battery: 步骤 1 中的图像 3,3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 2 中的图像 1,1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Interior Case Replacement, Exterior Case: 步骤 3 中的图像 1,1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 4 中的图像 1,1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 5 中的图像 1,1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 6 中的图像 1,1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 7 中的图像 1,1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 8 中的图像 1,1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 9 中的图像 1,2 Fujifilm FinePix XP80 Interior Case Replacement: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Interior Case Replacement, Interior Case: 步骤 10 中的图像 1,1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 11 中的图像 1,1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 12 中的图像 1,1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 13 中的图像 1,3 Fujifilm FinePix XP80 Interior Case Replacement: 步骤 13 中的图像 2,3 Fujifilm FinePix XP80 Interior Case Replacement: 步骤 13 中的图像 3,3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Interior Case Replacement: 步骤 14 中的图像 1,1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
结论
Amanda Lewis
于09/25/16注册
317 声望
创作了3篇指南
团队
USF Tampa, Team 1-3, Cagle Fall 2016 USF Tampa, Team 1-3, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G3
5 名成员
创作了14篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 432
