跳转到主内容
Fujifilm FinePix XP80 Shutter Button Replacement
你所需要的
  1. Fujifilm FinePix XP80  Shutter Button Replacement, Battery: 步骤 1 中的图像 1,3 Fujifilm FinePix XP80  Shutter Button Replacement, Battery: 步骤 1 中的图像 2,3 Fujifilm FinePix XP80  Shutter Button Replacement, Battery: 步骤 1 中的图像 3,3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80  Shutter Button Replacement: 步骤 2 中的图像 1,1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80  Shutter Button Replacement, Exterior Case: 步骤 3 中的图像 1,1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80  Shutter Button Replacement: 步骤 4 中的图像 1,1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80  Shutter Button Replacement: 步骤 5 中的图像 1,1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80  Shutter Button Replacement: 步骤 6 中的图像 1,1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80  Shutter Button Replacement: 步骤 7 中的图像 1,1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80  Shutter Button Replacement: 步骤 8 中的图像 1,1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80  Shutter Button Replacement: 步骤 9 中的图像 1,2 Fujifilm FinePix XP80  Shutter Button Replacement: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80  Shutter Button Replacement, Shutter Button: 步骤 10 中的图像 1,2 Fujifilm FinePix XP80  Shutter Button Replacement, Shutter Button: 步骤 10 中的图像 2,2
    • Once the exterior case is removed, separate the plastic depressor to ensure there is nothing lodged in or around the button, preventing proper functionality.
结论
另外一个人完成了本指南。
Daniela Pesci
于09/28/16注册
194 声望
创作了2篇指南
团队
USF Tampa, Team 1-3, Cagle Fall 2016 USF Tampa, Team 1-3, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G3
5 名成员
创作了14篇指南
2指南评论
Do you know where I can get replacement shutter button parts for this camera.
DEAN MURPHY - 回复
Where can I buy the shutter button components for this camera?
DEAN MURPHY - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 15
总计 957
