跳转到主内容
Fujifilm FinePix XP70 Front and Back Panel Replacement
你所需要的
  1. Fujifilm FinePix XP70 Front and Back Panel Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 2 中的图像 1,2 Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 2 中的图像 2,2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 3 中的图像 1,1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Front and Back Panel Replacement, Front and Back Panel: 步骤 4 中的图像 1,1
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  5. Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 5 中的图像 1,1
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  6. Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 6 中的图像 1,1
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  7. Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 7 中的图像 1,1
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  8. Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 8 中的图像 1,2 Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 8 中的图像 2,2
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  9. Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 9 中的图像 1,1
    • Lift off the front plate.
  10. Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 10 中的图像 1,3 Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 10 中的图像 2,3 Fujifilm FinePix XP70 Front and Back Panel Replacement: 步骤 10 中的图像 3,3
    • Pry the back plate off with a plastic opening tool
结论
Olivia A
于10/24/16注册
484 声望
创作了4篇指南
团队
UMass Dartmouth, Team S7-G3, Julie Spring 2017 UMass Dartmouth, Team S7-G3, Julie Spring 2017 的会员
UMASSD-JULIE-S17S7G3
4 名成员
创作了12篇指南
一条评论
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
Jose Gerardo Hernandez Montiel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 387
