跳转到主内容
Fujifilm FinePix XP70 Button Replacement
你所需要的
  1. Fujifilm FinePix XP70 Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Button Replacement: 步骤 2 中的图像 1,2 Fujifilm FinePix XP70 Button Replacement: 步骤 2 中的图像 2,2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Button Replacement: 步骤 3 中的图像 1,1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Button Replacement, Button: 步骤 4 中的图像 1,2 Fujifilm FinePix XP70 Button Replacement, Button: 步骤 4 中的图像 2,2
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP70 Button Replacement: 步骤 5 中的图像 1,1
    • Pull the three buttons out.
结论
Olivia A
于10/24/16注册
484 声望
创作了4篇指南
团队
UMass Dartmouth, Team S7-G3, Julie Spring 2017 UMass Dartmouth, Team S7-G3, Julie Spring 2017 的会员
UMASSD-JULIE-S17S7G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 274
