跳转到主内容
Fujifilm FinePix XP50 Rear Case Replacement
你所需要的
  1. Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,3 Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,3 Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
    • Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
  2. Fujifilm FinePix XP50 Rear Case Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix XP50 Rear Case Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix XP50 Rear Case Replacement: 步骤 2 中的图像 3,3
    • Using Phillips #00 screwdriver, remove 3.0 mm screws on the bottom of the camera closer to the back.
    • Using Phillips #00 screwdriver remove two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
  3. Fujifilm FinePix XP50 Rear Case Replacement: 步骤 3 中的图像 1,1
    • Using Phillips #00 screwdriver, remove the two 3.0 mm screws.
  4. Fujifilm FinePix XP50 Rear Case Replacement: 步骤 4 中的图像 1,3 Fujifilm FinePix XP50 Rear Case Replacement: 步骤 4 中的图像 2,3 Fujifilm FinePix XP50 Rear Case Replacement: 步骤 4 中的图像 3,3
    • Using 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
    • Using Phillips #00 screwdriver, remove 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
  5. Fujifilm FinePix XP50 Rear Case Replacement: 步骤 5 中的图像 1,3 Fujifilm FinePix XP50 Rear Case Replacement: 步骤 5 中的图像 2,3 Fujifilm FinePix XP50 Rear Case Replacement: 步骤 5 中的图像 3,3
  6. Fujifilm FinePix XP50 Rear Case Replacement: 步骤 6 中的图像 1,3 Fujifilm FinePix XP50 Rear Case Replacement: 步骤 6 中的图像 2,3 Fujifilm FinePix XP50 Rear Case Replacement: 步骤 6 中的图像 3,3
    • Using Phillips #00 screwdriver, remove seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
结论
另外一个人完成了本指南。
Paulo Abalos
于03/20/15注册
122 声望
撰写一个指南
团队
Baylor, Team 2-4, Grigsby Spring 2015 Baylor, Team 2-4, Grigsby Spring 2015 的会员
BU-GRIGSBY-S15S2G4
4 名成员
创作了8篇指南
一条评论
where can I buy the Fujifilm FinePix XP50 Rear Case?
CO - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 791
