跳转到主内容
Fujifilm FinePix XP50 LCD Screen Replacement
你所需要的
  1. Fujifilm FinePix XP50 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 2 中的图像 1,2 Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP50 LCD Screen Replacement, Button: 步骤 4 中的图像 1,2 Fujifilm FinePix XP50 LCD Screen Replacement, Button: 步骤 4 中的图像 2,2
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Pull the three buttons out.
  6. Fujifilm FinePix XP50 LCD Screen Replacement, Front and Back Panel: 步骤 6 中的图像 1,1
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  7. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  8. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  9. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  10. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 10 中的图像 1,2 Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  11. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Lift off the front plate.
  12. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 12 中的图像 1,3 Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 12 中的图像 2,3 Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 12 中的图像 3,3
    • Pry the back plate off with a plastic opening tool
  13. Fujifilm FinePix XP50 LCD Screen Replacement, Back Panel: 步骤 13 中的图像 1,1
    • Pry the two latches off using a spudger.
    • It takes some force to pry the latches off, so be careful to not break them.
  14. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 14 中的图像 1,3 Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 14 中的图像 2,3 Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 14 中的图像 3,3
    • Pry the remaining latches with a plastic opening tool.
    • It's best to start on the opposite side. Then pry off the top and end at the bottom.
    • It may take some force to remove this, but be careful to not break the latches off.
  15. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 15 中的图像 1,1
    • Pull the two halves apart.
    • Reattach the LCD ribbon cable into the slot before closing the halves when reassembling.
  16. Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 16 中的图像 1,2 Fujifilm FinePix XP50 LCD Screen Replacement: 步骤 16 中的图像 2,2
    • Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
    • Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
  17. Fujifilm FinePix XP50 LCD Screen Replacement, LCD Screen: 步骤 17 中的图像 1,1
    • Use the plastic opening tool to gently lift the LCD screen up.
结论
Cory Teixeira
于03/24/17注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team S7-G3, Julie Spring 2017 UMass Dartmouth, Team S7-G3, Julie Spring 2017 的会员
UMASSD-JULIE-S17S7G3
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 12
总计 520
