你所需要的
Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
Use a T5 Torx bit to secure the exterior decorative cover of the device.
Locate the ribbon cable attachment for the rear panel controls.
Gently lift the ribbon cable securing bar and slide the ribbon cable from the socket in order to remove the rear control panel.
2等其他人完成本指南。
