跳转到主内容
Fujifilm FinePix XP10SE LCD Replacement
你所需要的
  1. Fujifilm FinePix XP10SE LCD Replacement, Lens: 步骤 1 中的图像 1,1
    • Remove the screws from the lens cover
  2. Fujifilm FinePix XP10SE LCD Replacement: 步骤 2 中的图像 1,1
    • Remove the screws from the side metal cover of outer case.
  3. Fujifilm FinePix XP10SE LCD Replacement: 步骤 3 中的图像 1,2 Fujifilm FinePix XP10SE LCD Replacement: 步骤 3 中的图像 2,2
    • Gently remove the Lens from the housing.
  4. Fujifilm FinePix XP10SE LCD Replacement, Front Cover: 步骤 4 中的图像 1,3 Fujifilm FinePix XP10SE LCD Replacement, Front Cover: 步骤 4 中的图像 2,3 Fujifilm FinePix XP10SE LCD Replacement, Front Cover: 步骤 4 中的图像 3,3
    • Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
    • Use a T5 Torx bit to secure the exterior decorative cover of the device.
  5. Fujifilm FinePix XP10SE LCD Replacement: 步骤 5 中的图像 1,2 Fujifilm FinePix XP10SE LCD Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to detach the case.
  6. Fujifilm FinePix XP10SE LCD Replacement: 步骤 6 中的图像 1,2 Fujifilm FinePix XP10SE LCD Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opening tool to cautiously pry the casing off of the camera.
  7. Fujifilm FinePix XP10SE LCD Replacement: 步骤 7 中的图像 1,3 Fujifilm FinePix XP10SE LCD Replacement: 步骤 7 中的图像 2,3 Fujifilm FinePix XP10SE LCD Replacement: 步骤 7 中的图像 3,3
    • Carefully slide the case to the left. Avoid cracking the case on the lens.
  8. Fujifilm FinePix XP10SE LCD Replacement, LCD: 步骤 8 中的图像 1,1
    • Locate the securing tabs of the housing unit.
    • Using the spongerslowly work your way around the outside of the case using the sponging tool to pry open the case.
    • *** Take extreme caution when doing this being careful not to break the securing tabs of the housing.
  9. Fujifilm FinePix XP10SE LCD Replacement: 步骤 9 中的图像 1,1
    • Once the case is open locate the Ribbon cable attachment for the LCD screen.
    • Carefully ensure that the LCD screen is free from all attachments and any tape securing the ribbon cable is released.
  10. Fujifilm FinePix XP10SE LCD Replacement: 步骤 10 中的图像 1,2 Fujifilm FinePix XP10SE LCD Replacement: 步骤 10 中的图像 2,2
    • Gently lift up on the black securing bar of the ribbon cable in order to free it from the units motherboard, thus releasing the LCD from the computer.
结论
另外一个人完成了本指南。
Bryan
于01/25/15注册
598 声望
创作了5篇指南
团队
Pasco Hernando, Team 5-1, Prince Winter 2015 Pasco Hernando, Team 5-1, Prince Winter 2015 的会员
PHSC-PRINCE-W15S5G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 169
