跳转到主内容
Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement
你所需要的
  1. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, LCD Screen: 步骤 1 中的图像 1,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, LCD Screen: 步骤 1 中的图像 2,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 2 中的图像 3,3
    • Open the battery chamber and remove the battery.
    • Pry the front half of the casing from the camera.
    • Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
  3. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 3 中的图像 1,2 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 4 中的图像 1,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 4 中的图像 2,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 4 中的图像 3,3
    • Lift the LCD screen out of the camera.
    • There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
  5. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, Lens: 步骤 5 中的图像 1,1
    • Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
  6. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 6 中的图像 1,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 6 中的图像 2,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 6 中的图像 3,3
    • Pry the center casing off the camera. This is best done by separating the top and side sections individually.
  7. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 7 中的图像 1,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 7 中的图像 2,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 7 中的图像 3,3
    • Unscrew the two 3.5 mm Phillips head screws in the metal plate.
  8. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 8 中的图像 1,2 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 8 中的图像 2,2
    • Pry the metal plate out using the spudger.
  9. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 9 中的图像 1,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 9 中的图像 2,3 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 9 中的图像 3,3
    • Peel back the strip of black tape to reveal a red and black wire.
    • Detach the orange ribbon by gently pulling on it.
    • Detach the golden ribbon by gently lifting it with the spudger.
  10. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 10 中的图像 1,2 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 10 中的图像 2,2
    • The lens should now be free to simply be pushed out of its socket.
    • The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
  11. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, Motherboard: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to pull back the plastic covering the top of the camera.
  12. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 12 中的图像 1,2 Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 12 中的图像 2,2
    • Use tweezers to disconnect both the red and the black wires located next to the flash of the camera.
    • These wires will need to be soldered back in place upon reassembly.
  13. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 13 中的图像 1,1
    • Pry off the top circuit board using the spudger.
  14. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 14 中的图像 1,1
    • Use tweezers to disconnect the blue and white wires on the underside of the camera.
  15. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement: 步骤 15 中的图像 1,1
    • Push the motherboard out of the camera body.
  16. Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement, Shutter and Power Button Circuit Board: 步骤 16 中的图像 1,1
    • Detach the red, black, and white wires from the circuit board that you pried off earlier.
    • You will have to solder these wires in the same locations on your replacement circuit board. Removing the motherboard makes accessing the wires easier and eliminates the risk of the motherboard being damaged from a soldering accident.
结论
另外一个人完成了本指南。
George Lindner
于01/20/15注册
237 声望
创作了2篇指南
团队
USF Tampa, Team 19-3, Blackwell Winter 2015 USF Tampa, Team 19-3, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S19G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 445
