跳转到主内容
Fujifilm FinePix T500 LCD Screen Replacement
你所需要的
  1. Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 LCD Screen Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix T500 LCD Screen Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix T500 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Open the battery chamber and remove the battery.
    • Pry the front half of the casing from the camera.
    • Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
  3. Fujifilm FinePix T500 LCD Screen Replacement: 步骤 3 中的图像 1,2 Fujifilm FinePix T500 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 LCD Screen Replacement: 步骤 4 中的图像 1,3 Fujifilm FinePix T500 LCD Screen Replacement: 步骤 4 中的图像 2,3 Fujifilm FinePix T500 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Lift the LCD screen out of the camera.
    • There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
结论
George Lindner
于01/20/15注册
237 声望
创作了2篇指南
团队
USF Tampa, Team 19-3, Blackwell Winter 2015 USF Tampa, Team 19-3, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S19G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 622
