简介
This is a guide for removing the back case of the Fujifilm FinePix S9500 camera. The back case is responsible for protecting the delicate electronics housed within. This guide will also show you how to remove the case top.
你所需要的
Locate and remove two screws. They are M1.7 x 5.0 in size.
The first screw is below and to the left of the command dial on the back of the camera.
The second screw is on the right side of the camera, to the right of the strap mount.
There are four screws on the right side of the camera that need to be removed.
To the left of the AE-L dial, there is a brace that needs to be removed. Take out the screw from that panel.
Remove the white LCD FPC from the camera back and the orange LCD FPC from the main body to separate the camera. Start by gently pulling the white LCD FPC away from the back of the camera, then remove the orange LCD FPC from the main body of the camera.
