你所需要的
Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
Take the back casing and push the button panel out gently. The panel will easily fall out and can easily be replaced.
即将完成!
结论
