跳转到主内容
Fujifilm FinePix S8630 Battery Door Replacement
你所需要的
  1. Fujifilm FinePix S8630 Battery Door Replacement, Battery Door: 步骤 1 中的图像 1,1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Battery Door Replacement: 步骤 2 中的图像 1,1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Battery Door Replacement: 步骤 3 中的图像 1,1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Battery Door Replacement: 步骤 4 中的图像 1,2 Fujifilm FinePix S8630 Battery Door Replacement: 步骤 4 中的图像 2,2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Battery Door Replacement: 步骤 5 中的图像 1,1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Battery Door Replacement: 步骤 6 中的图像 1,3 Fujifilm FinePix S8630 Battery Door Replacement: 步骤 6 中的图像 2,3 Fujifilm FinePix S8630 Battery Door Replacement: 步骤 6 中的图像 3,3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Battery Door Replacement: 步骤 7 中的图像 1,3 Fujifilm FinePix S8630 Battery Door Replacement: 步骤 7 中的图像 2,3 Fujifilm FinePix S8630 Battery Door Replacement: 步骤 7 中的图像 3,3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
结论
团队
USF Tampa, Team 3-2, Sullivan Spring 2016 USF Tampa, Team 3-2, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S3G2
4 名成员
创作了12篇指南
一条评论
I have just replaced the battery door.
There is no need to to do Step 7.
At step 6 when prying the front and back open.
You can insert the new battery cover simply by inserting the cover on an angle.
The two lugs will just fit into the cavity.
Close and insert all screws.
Job is finished.
norman laundry - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 699
