跳转到主内容
Fujifilm FinePix S8200 Selector Replacement
你所需要的
  1. Fujifilm FinePix S8200 Selector  Replacement, Batteries: 步骤 1 中的图像 1,1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Selector  Replacement: 步骤 2 中的图像 1,1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Selector  Replacement: 步骤 3 中的图像 1,1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: 步骤 4 中的图像 1,3 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: 步骤 4 中的图像 2,3 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: 步骤 4 中的图像 3,3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. Fujifilm FinePix S8200 Selector  Replacement: 步骤 5 中的图像 1,3 Fujifilm FinePix S8200 Selector  Replacement: 步骤 5 中的图像 2,3 Fujifilm FinePix S8200 Selector  Replacement: 步骤 5 中的图像 3,3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. Fujifilm FinePix S8200 Selector  Replacement: 步骤 6 中的图像 1,1
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. Fujifilm FinePix S8200 Selector  Replacement, Removing Selection Button: 步骤 7 中的图像 1,1
    • To Replace the Selection button, carefully pull the button until the button has been fully detached.
结论
另外一个人完成了本指南。
Ugent Dailey
于01/20/15注册
119 声望
撰写一个指南
团队
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G1
4 名成员
创作了9篇指南
一条评论
preciso dessa peça.. aonde consigo encontrar para comprar? email: smchous@hotmail.com
smchous - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 1,105
