跳转到主内容
Fujifilm FinePix S8200 LCD Screen Replacement
你所需要的
  1. Fujifilm FinePix S8200 LCD Screen  Replacement, Batteries: 步骤 1 中的图像 1,1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 LCD Screen  Replacement: 步骤 2 中的图像 1,1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 LCD Screen  Replacement: 步骤 3 中的图像 1,1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: 步骤 4 中的图像 1,3 Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: 步骤 4 中的图像 2,3 Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: 步骤 4 中的图像 3,3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. Fujifilm FinePix S8200 LCD Screen  Replacement: 步骤 5 中的图像 1,3 Fujifilm FinePix S8200 LCD Screen  Replacement: 步骤 5 中的图像 2,3 Fujifilm FinePix S8200 LCD Screen  Replacement: 步骤 5 中的图像 3,3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. Fujifilm FinePix S8200 LCD Screen  Replacement: 步骤 6 中的图像 1,1
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. Fujifilm FinePix S8200 LCD Screen  Replacement, LCD Screen: 步骤 7 中的图像 1,2 Fujifilm FinePix S8200 LCD Screen  Replacement, LCD Screen: 步骤 7 中的图像 2,2
    • Fold back the LCD screen with the plastic opening tool.
    • Remove the cable coming from the LCD screen that goes into the motherboard.
结论
2等其他人完成本指南。
Joseph Kelley
于01/15/15注册
228 声望
创作了2篇指南
团队
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G1
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,264
