跳转到主内容
Fujifilm FinePix S8200 Batteries Replacement
  1. Fujifilm FinePix S8200 Batteries Replacement, Batteries: 步骤 1 中的图像 1,1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Batteries Replacement: 步骤 2 中的图像 1,1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Batteries Replacement: 步骤 3 中的图像 1,1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
结论
Insert your new batteries, close the battery chamber, and you're done!
Greg Sweeney
于01/14/15注册
137 声望
撰写一个指南
团队
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G1
4 名成员
创作了9篇指南
3条评论
should there be an indicator led to show the camera is charing ?
tony smith - 回复
should the camera indicate that it is being charged ?
tony smith - 回复
When changing battery the date and time is reset. Is there a backup battery ?
BRIAN STIFF - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 1,595
