跳转到主内容
Fujifilm FinePix S4200 Lens Replacement
你所需要的
  1. Fujifilm FinePix S4200 Lens Replacement, Lens: 步骤 1 中的图像 1,1
    • Turn off the camera by pushing the ON/OFF switch as shown.
  2. Fujifilm FinePix S4200 Lens Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix S4200 Lens Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix S4200 Lens Replacement: 步骤 2 中的图像 3,3
    • Using a Phillips #000 screwdriver, remove all of the 4mm screws from the left, right, and bottom of the camera.
  3. Fujifilm FinePix S4200 Lens Replacement: 步骤 3 中的图像 1,1
    • Remove casing part pictured by gently pulling up until casing is fully detached.
  4. Fujifilm FinePix S4200 Lens Replacement: 步骤 4 中的图像 1,3 Fujifilm FinePix S4200 Lens Replacement: 步骤 4 中的图像 2,3 Fujifilm FinePix S4200 Lens Replacement: 步骤 4 中的图像 3,3
    • Remove the 4 mm screws on the metal plate. Then remove the 4 mm screws on left side of the camera, and remove the two 4mm screws on right side.
    • Use the Phillips #000 to avoid stripping the screws.
  5. Fujifilm FinePix S4200 Lens Replacement: 步骤 5 中的图像 1,1
    • Remove orange ribbon cable by gently pulling on the cable until it is detached from the clamping device on the motherboard.
    • Remove the top casing by pulling upwards.
  6. Fujifilm FinePix S4200 Lens Replacement: 步骤 6 中的图像 1,2 Fujifilm FinePix S4200 Lens Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the LCD screen.
    • Gently pull on orange tab until it is free. This orange strip is susceptible to tearing.
  7. Fujifilm FinePix S4200 Lens Replacement: 步骤 7 中的图像 1,2 Fujifilm FinePix S4200 Lens Replacement: 步骤 7 中的图像 2,2
    • Remove remaining 4mm screw. Detach metal plate by lifting plate upwards.
    • Use the Phillips #000 screwdriver.
  8. Fujifilm FinePix S4200 Lens Replacement: 步骤 8 中的图像 1,1
    • Remove remaining orange tabs on motherboard by gently pulling on all tab until they are free.
    • Caution: Orange strips are susceptible to tearing.
  9. Fujifilm FinePix S4200 Lens Replacement: 步骤 9 中的图像 1,1
    • Using the Phillips #000 screwdriver, remove the 4mm screws in the corners of the motherboard.
  10. Fujifilm FinePix S4200 Lens Replacement: 步骤 10 中的图像 1,1
    • Use a soldering iron to desolder the five connections shown.
    • Caution: After removing the soldered connections, they must be given ample time to cool before moving to the next step.
  11. Fujifilm FinePix S4200 Lens Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard. It should be free of all connections at this point and can be lifted with ease.
  12. Fujifilm FinePix S4200 Lens Replacement: 步骤 12 中的图像 1,2 Fujifilm FinePix S4200 Lens Replacement: 步骤 12 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the 4mm screws around the metal plate.
    • Using a Phillips #000 screwdriver, remove the 10mm screws.
  13. Fujifilm FinePix S4200 Lens Replacement: 步骤 13 中的图像 1,1
    • Slowly lift up the metal plate and remove it from the camera.
  14. Fujifilm FinePix S4200 Lens Replacement: 步骤 14 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the 10mm screw.
  15. Fujifilm FinePix S4200 Lens Replacement: 步骤 15 中的图像 1,2 Fujifilm FinePix S4200 Lens Replacement: 步骤 15 中的图像 2,2
    • Remove the inner lens.
    • Caution: Be careful while removing the lens.
  16. Fujifilm FinePix S4200 Lens Replacement: 步骤 16 中的图像 1,1
    • Change the broken inner lens with a new inner lens.
    • Reassemble the camera.
结论
Joshua Greer
于10/31/18注册
253 声望
撰写一个指南
团队
IUPUI, Team S1-G5, Harley Fall 2018 IUPUI, Team S1-G5, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S1G5
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 45
总计 2,363
