跳转到主内容
Fujifilm FinePix S2980 Speaker Replacement
你所需要的
  1. Fujifilm FinePix S2980 Speaker Replacement, LCD Screen: 步骤 1 中的图像 1,3 Fujifilm FinePix S2980 Speaker Replacement, LCD Screen: 步骤 1 中的图像 2,3 Fujifilm FinePix S2980 Speaker Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Use a PH0 screwdriver to remove four screws on the right side, three screws on the bottom, and four on the left side to take off the rear plate.
  2. Fujifilm FinePix S2980 Speaker Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix S2980 Speaker Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix S2980 Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the three screws holding the LCD screen in place.
    • Replace with new screen.
  3. Fujifilm FinePix S2980 Speaker Replacement, Speaker: 步骤 3 中的图像 1,3 Fujifilm FinePix S2980 Speaker Replacement, Speaker: 步骤 3 中的图像 2,3 Fujifilm FinePix S2980 Speaker Replacement, Speaker: 步骤 3 中的图像 3,3
    • Remove the two screws from underneath the flash mechanism.
    • Remove the two screws placed on the right and left sides of the camera.
  4. Fujifilm FinePix S2980 Speaker Replacement: 步骤 4 中的图像 1,1
    • Use the opening tool to pry the top plate off of the top of the camera.
  5. Fujifilm FinePix S2980 Speaker Replacement: 步骤 5 中的图像 1,2 Fujifilm FinePix S2980 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the four larger silver plated screws placed on the inside of the lens.
    • Remove the lens by lifting it up from the cavity.
  6. Fujifilm FinePix S2980 Speaker Replacement: 步骤 6 中的图像 1,3 Fujifilm FinePix S2980 Speaker Replacement: 步骤 6 中的图像 2,3 Fujifilm FinePix S2980 Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the five bracket screws.
  7. Fujifilm FinePix S2980 Speaker Replacement: 步骤 7 中的图像 1,2 Fujifilm FinePix S2980 Speaker Replacement: 步骤 7 中的图像 2,2
    • Once the screws are out, remove the the bracket
    • Remove speaker with given tweezer tool and replace
结论
2等其他人完成本指南。
diane heidke
于03/24/15注册
24 声望
撰写一个指南
团队
UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 15
总计 1,114
