跳转到主内容
Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement
你所需要的
  1. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, LCD Screen: 步骤 1 中的图像 1,3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, LCD Screen: 步骤 1 中的图像 2,3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Use a PH0 screwdriver to remove four screws on the right side, three screws on the bottom, and four on the left side to take off the rear plate.
  2. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 步骤 2 中的图像 3,3
    • Remove the three screws holding the LCD screen in place.
    • Replace with new screen.
  3. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, Flash Mechanism Latch Spring: 步骤 3 中的图像 1,3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, Flash Mechanism Latch Spring: 步骤 3 中的图像 2,3 Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, Flash Mechanism Latch Spring: 步骤 3 中的图像 3,3
    • Remove the two screws from underneath the flash mechanism.
    • Remove the two screws placed on the right and left sides of the camera.
  4. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 步骤 4 中的图像 1,1
    • Pry the top of the camera off using the given tool
  5. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 步骤 5 中的图像 1,1
    • Remove two silver plated screw from under the top of the camera, under the flash.
  6. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 步骤 6 中的图像 1,1
    • Remove the rectangular plastic piece.
  7. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: 步骤 7 中的图像 1,1
    • Insert new spring.
    • Replace the plastic piece.
结论
Megan Merlo
于03/24/15注册
78 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 1,101
