跳转到主内容
Fujifilm FinePix HS30EXR Motherboard Replacement
你所需要的
  1. Fujifilm FinePix HS30EXR Motherboard Replacement, Frame: 步骤 1 中的图像 1,1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 2 中的图像 1,1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 3 中的图像 1,1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 4 中的图像 1,1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 5 中的图像 1,1
  6. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 6 中的图像 1,1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 7 中的图像 1,2 Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 7 中的图像 2,2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 9 中的图像 1,1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 10 中的图像 1,1
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 11 中的图像 1,1
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 12 中的图像 1,1
  13. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 13 中的图像 1,1
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 14 中的图像 1,1
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the motherboard.
结论
另外一个人完成了本指南。
Andrew Scouten
于10/22/18注册
838 声望
创作了5篇指南
团队
Baylor, Team S1-G2, Williams Fall 2018 Baylor, Team S1-G2, Williams Fall 2018 的会员
BU-WILLIAMS-F18S1G2
4 名成员
创作了12篇指南
2指南评论
have you instructions to remove power on and selector assembly?
renato.ciccone - 回复
have you istructions to remove the poweron switch asm. for the hs30exr?
renato.ciccone - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 1,372
