跳转到主内容
Fujifilm FinePix HS30EXR Frame Replacement
你所需要的
  1. Fujifilm FinePix HS30EXR Frame Replacement, Frame: 步骤 1 中的图像 1,1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Frame Replacement: 步骤 2 中的图像 1,1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Frame Replacement: 步骤 3 中的图像 1,1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Frame Replacement: 步骤 4 中的图像 1,1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Frame Replacement: 步骤 5 中的图像 1,1
  6. Fujifilm FinePix HS30EXR Frame Replacement: 步骤 6 中的图像 1,1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Frame Replacement: 步骤 7 中的图像 1,2 Fujifilm FinePix HS30EXR Frame Replacement: 步骤 7 中的图像 2,2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
结论
Andrew Scouten
于10/22/18注册
838 声望
创作了5篇指南
团队
Baylor, Team S1-G2, Williams Fall 2018 Baylor, Team S1-G2, Williams Fall 2018 的会员
BU-WILLIAMS-F18S1G2
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 807
