跳转到主内容
Fujifilm FinePix HS30EXR Battery Replacement
你所需要的
  1. Fujifilm FinePix HS30EXR Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • To gain access to the battery, flip the camera so that is upside down.
    • Pull on the lever while at the same time pulling outwards, away from the device.
  2. Fujifilm FinePix HS30EXR Battery Replacement: 步骤 2 中的图像 1,1
    • Open the battery compartment.
    • Pull the grey lever towards the device; this should dislodge the battery from the compartment.
  3. Fujifilm FinePix HS30EXR Battery Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out of the compartment, and replace it with a newly functional battery.
结论
Andrew Scouten
于10/22/18注册
838 声望
创作了5篇指南
团队
Baylor, Team S1-G2, Williams Fall 2018 Baylor, Team S1-G2, Williams Fall 2018 的会员
BU-WILLIAMS-F18S1G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 735
