跳转到主内容
Fujifilm FinePix AX665 Lens Housing Replacement
你所需要的
  1. Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: 步骤 1 中的图像 1,3 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: 步骤 1 中的图像 2,3 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: 步骤 1 中的图像 3,3
    • Use a #00 Phillips screwdriver to remove all six screws around the camera that is holding the case.
  2. Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 2 中的图像 3,3
    • Use a plastic pick to separate each side of the camera case apart.
  3. Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 3 中的图像 1,2 Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 3 中的图像 2,2
    • Remove the ribbon cable from the side of the logic board.
  4. Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 4 中的图像 1,2 Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 4 中的图像 2,2
    • Remove the four metal clips around the camera until you can feel the metal bracket that holds the screen pop off.
  5. Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 5 中的图像 1,2 Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 5 中的图像 2,2
    • Carefully flip the screen and remove the ribbon cable attaching it to the logic board.
  6. Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 6 中的图像 1,1
    • Remove the three screws holding the sensor.
  7. Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 7 中的图像 1,1
    • Remove the sensor ribbon cable from the logic board.
  8. Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 8 中的图像 1,1
    • Remove the lens housing ribbon cable.
  9. Fujifilm FinePix AX665 Lens Housing Replacement: 步骤 9 中的图像 1,1
    • Remove the lens housing by moving the gray clip holding the unit.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 299
