跳转到主内容
Fujifilm FinePix A350 Memory Card Replacement
  1. Fujifilm FinePix A350 Memory Card Replacement, Batteries: 步骤 1 中的图像 1,3 Fujifilm FinePix A350 Memory Card Replacement, Batteries: 步骤 1 中的图像 2,3 Fujifilm FinePix A350 Memory Card Replacement, Batteries: 步骤 1 中的图像 3,3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Memory Card Replacement, Memory Card: 步骤 2 中的图像 1,3 Fujifilm FinePix A350 Memory Card Replacement, Memory Card: 步骤 2 中的图像 2,3 Fujifilm FinePix A350 Memory Card Replacement, Memory Card: 步骤 2 中的图像 3,3
    • Locate the memory card in the long, thin slot above the battery compartment.
    • Using your thumb, push the memory card farther into the camera.
    • The memory card is spring-loaded and will pop out of the camera far enough to be removed by hand.
结论
Jaxon Cramer
于03/21/16注册
1,045 声望
创作了9篇指南
团队
Clemson, Team 6-4, Benson Spring 2016 Clemson, Team 6-4, Benson Spring 2016 的会员
CLEM-BENSON-S16S6G4
4 名成员
创作了17篇指南
一条评论
Bonjour monsieur,
Pourquoi je ‘arrive plus à voir les photos je peu les prendre mais pas les voir “erreurs écriture “
Carte sd vierge.
Merci pour votre aide et bonne soirée
oli.ber - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 50
总计 1,101
