跳转到主内容
Fujifilm FinePix A350 Battery Contact Replacement
你所需要的
  1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: 步骤 1 中的图像 1,3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: 步骤 1 中的图像 2,3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: 步骤 1 中的图像 3,3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: 步骤 2 中的图像 1,3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: 步骤 2 中的图像 2,3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: 步骤 2 中的图像 3,3
    • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
    • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
结论
Jaxon Cramer
于03/21/16注册
1,045 声望
创作了9篇指南
团队
Clemson, Team 6-4, Benson Spring 2016 Clemson, Team 6-4, Benson Spring 2016 的会员
CLEM-BENSON-S16S6G4
4 名成员
创作了17篇指南
一条评论
It turned on after lifting up contact. Thank you, but we figured it out as I started to begin reading.
David Justin Laylon - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 462
