简介
You will have to take off the back cover of the camera in order to access the glass display screen.
你所需要的
Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
Four 3.95mm Phillips screws located on the bottom of the camera
Two 3.95mm Phillips screws located on the right side of the camera
One 3.95mm Phillips screw located on the left side of the camera
Use the tweezers to grab the speaker (located on left side of the camera) and pull straight up.
Locate the orange ribbon that goes from the screen to the bottom side of the motherboard.
Stick the spudger under the ribbon clip connecting and lift it up. Use the tweezers to pull out the ribbon.
Use the pointed end of the spudger to unplug the connector for the pink and white screen wires by pulling it straight out.
Wedge the plastic opening tool between the edge of the screen and the metal bracket, on the opposite side of the battery compartment.
Use the spudger to pry up the corner of the screen adjacent to the metal bracket.
The best place to wedge the tool is directly above the rectangular space in the bracket.
