跳转到主内容
Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement
你所需要的
  1. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Back Cover: 步骤 1 中的图像 1,3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Back Cover: 步骤 1 中的图像 2,3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 3 中的图像 1,3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 3 中的图像 2,3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 3 中的图像 3,3
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 4 中的图像 1,2 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
  6. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Button Circuit Board: 步骤 6 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the two screws on the bracket holding the right side of the button circuit board.
    • One 3.85mm Phillips #00 screw
    • One 3.4mm Phillips #00 screw
  7. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 7 中的图像 1,3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 7 中的图像 2,3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 7 中的图像 3,3
    • Use your fingers to remove the metal bracket and brown colored film.
  8. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 8 中的图像 1,3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 8 中的图像 2,3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: 步骤 8 中的图像 3,3
    • Use the spudger to pry up the clear plastic tab.
    • Pull the button receiver, button circuit board, and swivel button out as a single unit.
    • Jiggle the swivel button out of place if necessary.
结论
Sarah Daliva
于04/04/12注册
14 声望
创作了2篇指南
团队
Cal Poly, Team 14-8, Forte Spring 2012 Cal Poly, Team 14-8, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G8
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 23
总计 1,318
