简介
In order to access the battery compartment, the back cover of the camera needs to first be removed.
你所需要的
Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
Four 3.95mm Phillips screws located on the bottom of the camera
Two 3.95mm Phillips screws located on the right side of the camera
One 3.95mm Phillips screw located on the left side of the camera
Use the tweezers to grab the speaker (located on left side of the camera) and pull straight up.
Locate the wires running from the battery compartment to the main motherboard.
