跳转到主内容
Fujifilm FinePix 4700 Zoom Back Cover Replacement
你所需要的
  1. Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 步骤 2 中的图像 1,1
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 步骤 3 中的图像 1,3 Fujifilm FinePix 4700 Zoom Back Cover Replacement: 步骤 3 中的图像 2,3 Fujifilm FinePix 4700 Zoom Back Cover Replacement: 步骤 3 中的图像 3,3
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 步骤 4 中的图像 1,2 Fujifilm FinePix 4700 Zoom Back Cover Replacement: 步骤 4 中的图像 2,2
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 步骤 5 中的图像 1,1
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
结论
Sarthak Patel
于04/03/12注册
10 声望
创作了2篇指南
团队
Cal Poly, Team 14-8, Forte Spring 2012 Cal Poly, Team 14-8, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G8
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,141
