当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Locate the battery door.
Locate the latch on the battery door.
Use your finger pry to it open where it says "BATT."
Remove the battery from the camera by pulling the battery door outward.
Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
Squeeze the camera placing a thumb on the tab marked CE.
Pull the back half of the camera firmly away from the camera body.
Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
The plastic strip will now come off the camera body.
取消:我没有完成这个指南。
与7其他贡献者
于01/10/11注册
679 声望
创作了6篇指南
徽章: 10
+ 7更多徽章
CPSU-FORTE-W11S13G5
5 名成员
创作了11篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 13
总计 1,873
